part of the problem will be that in your file you the text "..." has been replaced with a single character unicode variation - each time i compile your file i need to do a global search and replace to fix that.
That would have been good to been told earlier. Please don't hesitate to bring problems to the table as they are discovered. I never get offended or hurt by criticism, and certainly not constructive criticism, so if there's something that needs to be dealt with, just tell me.
I'll swap the character (ellipsis) for three separate dots instead. Since Swedish often use more characters than English (in computer strings), using the ellipsis is a way to cut the strings by at least two characters.
As to track search, i see no reason it shouldnt work with #Main.menu.WebSearch# - perhaps there is a formatting issue in the file?
Not that I can find. At least not in the immediate vicinity of that string. I'll do a re-formatting back and forth. Let's see if that takes care of the problem, if it's a small glitch in a single character or line.
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
Du hittar svenska språkfiler i
den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
In
hoc filum documenta linguae Latinae nancisceris.
