could you add (or return?) support for empty localization strings?
and spaces will add extra separator between text parts/parameters.
i'll try to use spaces.
#Tag.ctl.origalb# original album:
#Main.field.177# Original Album
"Search Field Shortcuts" is in the file already as: #Main.menu.SeaFiSho#
and looking at the code #Tag.ctl.origalb# is being usedNot sure what is going on. Lets see if others report the same
regarding original album, i realise now that the prompt is overridden with the field header.
