#Sys.msg.WFcbmwattl# contains something weird strings.#Sys.msg.WFcbmwattl# WARNING: This setting allows MusicBee to automatically move files without prompting you." & Environment.NewLine & Environment.NewLine & "Files can be moved when added to the library and when editing tags." & Environment.NewLine & Environment.NewLine & "MusicBee will name a file using the naming rules you define and the file tag values.
Probably you omitted to check this one. MP3 is not limited anymore.#Sys.ctl.5F414CFE# Due to licensing restrictions, no MP3 or AAC encoder can be bundled with MusicBee.
#Main.ctl.JumpList# seems like missing.
There could be more missing items related to the followings as I only found them with my eyes on some dialogs.#Sys.btn.D0DD03D6##tField.ctl.883B02AD##tField.ctl.D8CDF2C2##tField.ctl.59524CFC##tField.ctl.75B9997B##tField.ctl.436D2FB9##tField.ctl.854434D3#!genre category editor#gCat.ctl.F1A8AF4D##gCat.ctl.F0C797E2#
not in the new file:#ASIO.ctl.566F807D##ASIO.btn.8A92D05B#no translation entry (the same asio panel):- device channel- speaker
#AP.ctl.50DBE52E# exists but it seems not enabled.
#Sys.msg.EdCopTagAll# Edit: Copy Tags, Artwork, Play Counters and RatingIs "Counters" here correct, not Counts?
