Author Topic: Translator Q&A  (Read 530198 times)
There is probably not much room for widening these fields in this panel to solve the cut-off descriptions here.
(I would need some 6 characters extra here)
If so, could there perhaps be hover-over pop-ups for those longer descriptions?
Since there are many panels, which can be confusing (especially for newbees), perhaps rename these to the a bit more specific:
View: Main Panel layout:
It seems that the button 'Reorganise' under Preferences> Library> Podcasts has no entry in the translation file.
Could this button be widened a bit?
It should say 'Bibliotheek Toevoegen', and there is no way to shorten that.
#Lib.btn.32CDB12D#
The caption 'Error' here has no entry in the translator file.
(choosing 'Inspect Tags' while no files selected)
I might have corrupted something in the language file, and before I perhaps do more damage I'll ask:
#Sys.btn.C07CA343# Equaliser && DSP...  as you can see has two ampersands.
I believe they are there on purpose, and when English is selected only one is displayed, but when I use it in my Dutch translation file, as you can see they both show up?
edit,
Checking some other translations (German, Polish), and they chose to replace '&&' with the word meaning 'and'.
Last Edit: August 03, 2016, 04:15:06 PM by hiccup
for the && issue, i think it should only be a single & in the text file for v3
for the issues you have reported i wouldnt be looking to change anything until v3.1
Ok, I'll change it.
But note that in the translator file (somewhere under 6-Mar) it still says:
! note: keep "&&" as-is
Steven, have found that couple of strings are truncated in latest mb though there is enough space:
klint
Hi Steven
It has likely already been reported, but I wasn't able to translate the strings below:
Thanks
Last Edit: October 12, 2016, 09:11:47 AM by klint
the text is actually user-defined in the Tags(1)/ Custom tags preferences, however i agree the default values should be translateable so i will look at that for v3.1
klint
Hello
Maybe this has already been reported, but anyway, just in case, here are 5 sentences that do not seem to be translated (during device sync):
1 here:
2 other here:
2 other here:
Cheers
Last Edit: October 14, 2016, 09:44:53 AM by klint
you are right but i will add translations for v3.1
except for the "Delete" button which will be translated with no change required by yourself
klint
Thanks Steven
Will it be the same for default values like Virtualx and Customx?
