Author Topic: Translator Q&A  (Read 529676 times)
#Sys.msg.WFcbmwattl# contains something weird strings.
#Sys.msg.WFcbmwattl# WARNING: This setting allows MusicBee to automatically move files without prompting you." & Environment.NewLine & Environment.NewLine & "Files can be moved when added to the library and when editing tags." & Environment.NewLine & Environment.NewLine & "MusicBee will name a file using the naming rules you define and the file tag values.
thats been adjusted to:
#Sys.msg.WFcbmwattl#  WARNING: This setting allows MusicBee to automatically move files without prompting you.{0}Files can be moved when added to the library and when editing tags.{1}MusicBee will name a file using the naming rules you define and the file tag values.
Probably you omitted to check this one. MP3 is not limited anymore.
#Sys.ctl.5F414CFE# Due to licensing restrictions, no MP3 or AAC encoder can be bundled with MusicBee.
i had already updated it but i see the new text for panel controls wasnt being picked up. It is now:
http://musicbee.niblseed.com/Localisation/EnglishGenerated3_0.txt
Last Edit: June 24, 2017, 10:42:24 AM by Steven
sheppaul
#Main.ctl.JumpList# seems like missing.
sheppaul
There could be more missing items related to the followings as I only found them with my eyes on some dialogs.
#Sys.btn.D0DD03D6#
#tField.ctl.883B02AD#
#tField.ctl.D8CDF2C2#
#tField.ctl.59524CFC#
#tField.ctl.75B9997B#
#tField.ctl.436D2FB9#
#tField.ctl.854434D3#
!genre category editor
#gCat.ctl.F1A8AF4D#
#gCat.ctl.F0C797E2#
Last Edit: June 22, 2017, 10:16:35 AM by sheppaul
not in the new file:
#ASIO.ctl.566F807D#
#ASIO.btn.8A92D05B#
no translation entry (the same asio panel):
- device channel
- speaker
#Sys.btn.D0DD03D6#
#gCat.ctl.F1A8AF4D#
#gCat.ctl.F0C797E2#
these are included now
#ASIO.ctl.566F807D#
#ASIO.btn.8A92D05B#
- device channel
- speaker
these are included now and the next translation file now has the items not translated
sheppaul
Could you please update v3.1 progress file together in the daily build folder if possible?
sheppaul
I'm working on. :)
#AP.ctl.50DBE52E# exists but it seems not enabled.
#Sys.msg.EdCopTagAll#   Edit: Copy Tags, Artwork, Play Counters and Rating
Is "Counters" here correct, not Counts?
Last Edit: June 24, 2017, 02:54:38 PM by sheppaul
if you are refering to its usage in the playlist mixer dialog then i have fixed that. Otherwise you will need to be specific where its not enabled
Counts is probably better
sheppaul
Yeah, it's from playlist mixer dialog.
Most of the entries in this Search and Replace panel are not present in the latest language file:
i have added those to the generated file
