Author Topic: Translator Q&A  (Read 529365 times)
I believe the entry: #AP.ctl.E34B56B1# is obsolete and was replaced by: #AP.btn.E34B56B1#, but it is still in the new 'generated' file.
But neither the successor #AP.btn.E34B56B1#, nor it's brother #AP.btn.534BF636# are in the new file.
Should they be?
I found one untranslated entry:
Device > Settings : "split files with a cuesheet into individual tracks"
thats in the not yet available 3.1 text
Should they be?
thats corrected now - its .btn.
And these seem to be missing from the new file:
#aNum.frm.7702B9A1#
#aNum.ctl.5D675CD#
#aNum.ctl.E100B1F5#
#aNum.ctl.294E79EF#
#aNum.ctl.8D9B6B69#
#aNum.ctl.B00EEF7E#
#aNum.ctl.6BE8657F#
these have been added:
aNum.ctl.E100B1F5
aNum.ctl.294E79EF
aNum.ctl.8D9B6B69
aNum.ctl.6BE8657F
http://musicbee.niblseed.com/Localisation/EnglishGenerated3_0.txt
Last Edit: June 24, 2017, 10:43:15 AM by Steven
aNum.ctl.E100B1F5
aNum.ctl.294E79EF
aNum.ctl.8D9B6B69
aNum.ctl.6BE8657F
Not this one?:
#aNum.ctl.B00EEF7E#
It does show in the MB panel.
no, aNum.msg.leze and aNum.msg.ee are used for that
Missing?:
#NPL.ctl.F2892F01#
#NPL.ctl.EBD7E277#
#NPL.ctl.53E6F98B#
#NPL.ctl.8EB6C56F#
#NPL.ctl.D61CDE74#
#NPL.ctl.31E584AA#
they are there now, plus a couple more from the same panel
#NPL.ctl.1DC51887#	prompt:
#NPL.ctl.774682F2# fields:
#NPL.ctl.ADB5BC21# contrast:
Last Edit: June 24, 2017, 10:43:05 AM by Steven
I can't find the translation entry for the hotkey: Tools: Locate Missing Files
thats new for v3.1 and not available yet
sheppaul
#Sys.ctl.3446BE8D#  is not applied to MusicBee in preferences - devices - configure
BTW, check the double quotation mark (""Love"") in your new reference file if it is allowed.
thanks
#Sys.ctl.3446BE8D# is fixed for next v3.1 release and the double quotes are corrected in the generated file
Last Edit: June 24, 2017, 10:42:50 AM by Steven
sheppaul
Probably you omitted to check this one. MP3 is not limited anymore.
#Sys.ctl.5F414CFE#   Due to licensing restrictions, no MP3 or AAC encoder can be bundled with MusicBee.
sheppaul
#Sys.msg.WFcbmwattl# contains something weird strings.
#Sys.msg.WFcbmwattl#   WARNING: This setting allows MusicBee to automatically move files without prompting you." & Environment.NewLine & Environment.NewLine & "Files can be moved when added to the library and when editing tags." & Environment.NewLine & Environment.NewLine & "MusicBee will name a file using the naming rules you define and the file tag values.
sheppaul
I think #Cvt.ctl.5E159E6C# should have a fixed width. It's an item in a file converter dialog. It does not break an english dialog but it does not fit in other translation if the translated one is shorter than the rest below in the dialog. Currently, I forcibly insert whitespaces in the end of #Cvt.ctl.5E159E6C#.
