MB uses linear by default. This is the BASS definition:
When using the linear curve, the volume range is from 0% (silent) to 100% (full). When using the logarithmic curve, the volume range is from -100 dB (effectively silent) to 0 dB (full). For example, a volume level of 0.5 is 50% linear or -50 dB logarithmic.
The linear curve is used by default.
Thanks, that's interesting, and a bit surprising.
Bass seems to have a different concept of what is linear than many (most) other applications or common agreement then.
The fact is that our ears have a logarithmical sensitivity to loudness, and any volume slider that doesn't compensate for that is a p.i.t.a. to use.
Using MusicBee's volume slider with the default setting, it most certainly feels- and sounds like it is nicely compensated for 'the logarithmic human ear'.
That's why I would think it would be called 'logarithmic'.
I'm sure the explanation from the Bass team is technically correct, but it's then probably based on some different principles or units related to voltage, percentages, dB scales or whatnot.
Also, it's probably not even an either/or matter since any sort and variation of a curve can be created for this.
Cut to the chase: Never mind, so it seems both terminologies can be defended as being 'correct'.
some reading material for people interested in getting their brain in a twist:
https://www.dr-lex.be/info-stuff/volumecontrols.htmlhttp://audioundone.com/different-fade-shapes
