Author Topic: Translator Q&A  (Read 530248 times)
I found a minor problem in track property window:
Replay gain values are not fully displayed.
i have made some changes for the next v2.5 update.
For the buttons, thats an issue with the skin
klint
No I'm using 2.5.5498. Which is the latest build I can get from the http://musicbee.niblseed.com/V2_5/ page.
Where is 2.5.5499??
klint
Yes, that's where I'm taking it from every day, but unless there is a pb of caching on my end (although I have refreshed it), the last version available to me is 5498 from Jan 20th
Fiy, with that version, the 'of' problem is now solved when using Dutch translation.
klint
Which version are you using? What is the date of the musicbee.exe file? I can't get hand on the 5499 version -the one I can download is 5498 :)
Thanks
I have exe version 2.5.5498.40465 filesize 6.403.072 bytes
(maybe Steven made a typo with '5499' either in his post or in the file properties?)
To be certain, we are both talking about this occurrence of 'of' correct?
klint
Yes that's it: http://vvcap.net/db/YLK2qIseg0q3YN_OXpIP.htp
(should be "de" instead of "of")
I also have checked in Dutch and yes, it is translated correctly in the interface :)
But not in French... I have verified my LNG file again, and the entry  is correctly set:   #Tag.ctl.of#      de
This problem is just a detail of course., but quite weird :)
Do you maybe have a duplicate #Tag.ctl.of# in your language file?
klint
Nope, only one :)
And actually, it seems to be translated correctly in other places where it is used:
http://vvcap.net/db/RyoPVylKZsxb4vToSYlJ.htp
Actually, the 'of' you are looking for is this one: #Main.msg.Proc0of1#
klint
Eureka!! That was it, thanks :)
And I was able to find 2 other similar untranslated strings in my LNG file. Corrected as well now
Last Edit: January 23, 2015, 12:37:12 PM by klint
Roadrunner
I just downloaded the version 2.5.5498. Could it be, that I need an even newer one?
its in the theater mode plugin - did you update that file?
You're right, one day to old, sorry.
klint
Hi Steven
The same string #Main.menu.RiCD# is used for both the menu and the CD node.
While on the menu it means "Rip *a* CD", on the CD node it means "Rip *the* cd" that is already inserted.
In French and likely other languages, the translation would have to be different.
But it's minor :)
