Author Topic: Translator Q&A  (Read 529367 times)
butty
Not-translated words exist in CD-ripping window: "in error" when failed in verification.
Please see: http://mb.piulento.net/tmp/mb-20150110-1.png
During synchronization, the "Status Sync" string is not translated. Yet it is at the end of the sync, showing the final status.
both have been added for the next update
There is a new entry: #Main.menu.ReseLi#   Reset List
I'm not sure how to translate. How and where do I invoke that command?
Is it different from #Main.menu.ClLi# Clear List ?
its in the Edit/Tag Undo menu i think when a playlist is cleared - see boroda74's request about it
Thnx for the quick reply.
I think I found it.
(I believe the functionality is not really working though, but that's not for this topic or concerning me right now)
And some semantics I have some troubles with:
In #Main.msg.CResArtCa# you mention 'downloading' and 'retrieving' as different entities. (but I 've run into this before)
I understand both terms, but in my language the differentiation between those two in computer terminology is a bit difficult.
Could you maybe briefly explain the functional difference between these two within Musicbee?
This entry from the latest translation file has the closing # missing:
#Rip.msg.SampFail#
There is a string named 'Fullscreen' which is not in the translator file.
It's the one at: View> Theater Mode> Theater Panel Dock> Fullscreen
edit:
And from that same tree there is also no entry for 'Normal Mode Settings:'
Last Edit: January 14, 2015, 11:58:20 AM by hiccup
There is an entry: #Main.menu.SeFilResc#   File Rescan
You can invoke that command both by right clicking a file or a folder.
When thriving for perfection in Dutch these technically should be translated slightly different.
If you feel there should be a differentiation for English too, please make a change.
If not I can make a slight change which will cover it for Dutch good enough.
These two entries are not reflected in MB when translated.
#Vol.ctl.801489EF#   on album basis
#Vol.ctl.8D1F1E51#   on track basis
I checked this both with Dutch and German translations.
downloading means MB is currently downloading the file
retrieving means MB is searching for matches although sometimes that continues onto being downloading but the status doesnt update
its the same function in MB so not something i can change easily
the other items are fixed for the next v2.5 update
Last Edit: January 14, 2015, 06:51:41 PM by Steven
#Main.menu.WebExplr#  is currently named 'Music Explorer'
I feel it might be more descriptive to name it 'Xbox Music Explorer' ?
If you don't recognize the icon in front of it, you'd have no idea what it is exactly.
