Author Topic: Translator Q&A  (Read 529571 times)
butty
Thanks Steven.
I will update the lang file for 1.
klint
Hello
I'm looking for the first new2.4.txt file published by Steven on April 24 (to compare it to the last ones and identify the changes).
I forgot to keep it myself :)
Thanks
the files are always incremental with new fields added to the end. So just look for "! 5-June"
Xyzzy
Apparently a word is missing:
"The path cannot be the same as or a sub-folder of one of the other rules"
it should be already in the file:
#Org.msg.Tpcbsaoaso#   The path cannot be the same as or a sub-folder of one of the other rules
Roadrunner
In the new pop-up window "Expanded Panel Settings" three texts are not translatable:
- The titel bar "Expanded Panel Settings"
- "auto-pick panel colours" (could be taken from "!Main.menu.Au-PiCo#")
- "fields displayed:"
@roadrunner, those have been added to the next file
Xyzzy
Isn't there word missing between 'as' and 'or'? Or do you mean: The path cannot be the same for multiple rules and cannot point to sub-folder of a path selected for any other rule?
i will change the english wording to:
The path cannot be the same as/ or a sub-folder of one of the other rules
Xyzzy
Should we report missing translations as of 2.4.5314, or are they still to be added to the language file?
i plan to make the final 2.4 beta available tonight along with the latest translation file
butty
Hi, I have found some translation related problems in 2.4.5315.
1. Settings->Layout(1): "show left and right sidebar open/ close buttons" is not in new2.4.txt.
See: http://mb.piulento.net/tmp/mb-20140722-2.png
2. Tool bar button settings: "when tabs are docked in the main panel:" (CB.msg.wtadimpb) is not translated.
See: http://mb.piulento.net/tmp/mb-20140722-1.png
for 1, i will post an updated translation file later
for 2, it should already be in the file:
#CB.msg.wtadimpb#   when tabs are docked in the main panel:
butty
Yes., it's in the file, but...
Although  I translated CB.msg.wtadimpb, it is not displayed in the Toolbar button settings.
i have uploaded an amended new.txt file with 2 new entries for translation.
For the 2nd issue, that is corrected in the new musicbee.exe
