Author Topic: Translator Q&A  (Read 530071 times)
Currently it works fine if Main.msg.Files1 is a translation of '{0} file' (with parameter). But its OK if you change conversion.
i will change it to use this convention:
#Main.msg.Files9:059#
#Main.msg.Files9:1#
#Main.msg.Files9:24#
this has the new convention:
http://musicbee.niblseed.com/V2_2/MusicBee_Exe_Patched.zip
Steven, thank you. All is working fine for Russian.
Xyzzy
Does it work for all 'number' ids ending with 9?
Yes. All is fine here.
Xyzzy
There is one correction to the numerals behaviour scheme (at least for Polish):
:059 should apply to any numerals ending with 11, 12, 13, 14 or any other number ending with 0,5-9
Xyzzy
thats fixed for the next v2.2 update
Thanks!
Boroda, Pako, are you OK with this change as well?
Pako
I do not know, I have not tried it yet.
Can you please give me piece of your file as an example?
I suppose it helps me to understand more quickly.
Thanks, Pako
Xyzzy
#Main.msg.Albums9:059#{0} albumów
#Main.msg.Albums9:1#{0} albumów
#Main.msg.Albums9:24#{0} albumy
Group by Artist in Artwork mode main panel - these are captions under Artist name
But the main question is -is your noun inflexion the same for numerals fe 12, 212 and 3012 or not. Previous implementation made them different (for 12 it is :059, but for 212 and  3012 it is :24), the new one makes them all use :059
Pako
Thanks.
Yes, also for the Czech language is suitable new implementation.
Pako
Yes. its required for Russian.
Xyzzy
It looks to me that #Scan.msg.CUtwctvft# does not respect new numerals convention when expanding placeholder.
could you reconfirm that as it looks fine to me using your polish translation
perhaps you meant something other than #Scan.msg.CUtwctvft#
Pako
The introduction of new conventions for plurals is great.
But it could be even better.
I found a few strings (IDs), for which should also be introduced similar conventions:
#TM.msg.hbaitl3d#
#TM.msg.hbaitlw#
#TM.msg.hbaitlm#
#TM.msg.mtcf#
#TM.msg.hbat#
#Sys.ctl.DCEF14B7#
#tTag.msg.  genres#
#Dup.col.352FB09C#
#AutoSD.msg.0in1mins#
#AutoSD.ctl.493A25AE#
#Main.msg.mins#
#Main.msg.hours#
#Main.msg.days#
#Scan.msg.Frac-a#
I suppose that this list is not exhaustive (and it is possible that something does not belong there).
Pako
