Author Topic: Translator Q&A  (Read 530074 times)
I have two questions:
1) What are the recommended dimensions of these buttons: #Image.PlayArtwork#, #Image.PlayArtworkSmall# and #Image.PlayArtworkNoButton# ?
2) In what situation will show an image #Image.PlayArtworkNoButton#?
1. i have uploaded the french ones:
http://www.mediafire.com/?8h869du9799y5fs
but if you want just let me know what the text should be and i will send back the base64 string you would use
2. having a look at the code its not used any more, so dont worry about that one
I found a typo (#Main.msg.UnstLDB#):
thanks - thats fixed for the next 2.2 update
Last Edit: July 19, 2013, 08:46:07 AM by Steven
Pako
i see its actually already available as:
#Main.menu.CoPl2#
Great! It really works!
But somewhere around oops mistake, because this identifier is absent in the localization file.
I checked it in Russian, German and Polish file. In none of them this string exists.
Thank you for the offer, but I do not need it. BTW - for me doing this job EventGhost (a Python script action):
You can see it in Czech localization file that is already done and I am here announcing earlier.
Pako
Xyzzy
A couple things:
- Could we have Polish play button as well? The text to put on it is:
Odtwórz
The third letter from the end is Latin small letter o with acute, Unicode 00F3 or LAlt+00243
- In Rip CD dialog, texts related to detected ripping problems, repairing them etc. (the ones displayed in Status column) are not localised
- In case of the IDs below, could we have separate versions for 2, 3, and 4 items, to accommodate for languages with paucal number (and also dual, trial and quadral) - like Polish
#Main.msg.Files1#
#Main.msg.Files9#
#Main.msg.SelFiles1#
#Main.msg.SelFiles9#
#Main.msg.DupFiles1#
#Main.msg.DupFiles9#
#Main.msg.NewFiles1#
#Main.msg.NewFiles9#
#Main.msg.Items1#
#Main.msg.Items9#
#Main.msg.Albums1#
#Main.msg.Albums9#
#Main.msg.Tracks1#
#Main.msg.Tracks9#
#Main.msg.Plays1#
#Main.msg.Plays9#
#Main.msg.Subs1#
#Main.msg.Subs9#
#Main.msg.Files1#
#Main.msg.Files9#
#Main.msg.Items1#
#Main.msg.Items9#
#Main.msg.Albums1#
#Main.msg.Albums9#
#Main.msg.Tracks1#
#Main.msg.Tracks9#
#Main.msg.Plays1#
#Main.msg.Plays9#
#Main.msg.Subs1#
#Main.msg.Subs9#
+1. It would be great to have #Main.msg.Files2_4#,  #Main.msg.SelFiles2_4#, etc. (2 to 4 items) strings.
BTW, in Russian (and I think in Polish also) string ID should depend on rightest digit of number, eg. for number 241 form #Main.msg.Files1# should be used.
Last Edit: July 26, 2013, 10:39:33 AM by boroda74
Xyzzy
Right. Almost. It's even a bit more complicated after I've thought about it a little, see below.
I think I have seen somewhere a mechanism for dynamic string selection - a set of formulas that are evaluated and the a string matching a formula is selected. Something along:
x==1;!((x-1)%10);x=11|x==12|x==13;!((x-2)%10)|!((x-3)%10)|!((x-4)%10);default#album;albumów;albumów;albumy;albumów
It reads:
one - album
any number ending with 1 - albumów
12, 13, 14 - albumów
any number ending with 2, 3 or 4 - albumy
default (all other) - albumów
Pako
Odtwórz
If you are interested, I can do it for you. I think Steven can do more useful work.
+1
In Czech language, of course, we have the same problems with the ending of the word.
Pako
Well, the Russian requirements are almost the same as Polish, but 11 must have the form 'albomov' and any other number ending with 1 form 'albom'. So we need for Slavic languages the following forms of strings:
  • 1 item
  • 11, 12, 13, 14 items or any other number ending with 5-9
  • any other number ending with 1
  • any other number ending with 2, 3, 4
Pako, please confirm that this acceptable for Czech.
Pako
  • 1 item
Yes, it is perfectly suitable for Czech.
Pako
Xyzzy
  • 1 item
It's OK for Polish as well, one correction though - second point should include numbers ending with 5-9 and ending with 0
so i will do:
  • No items - already done
  • 1 item - already done
  • any number ending with 0 - not used apart from polish
  • any other number - use the existing plural value
and if any of the rules are missing MB will use the existing plural value.
I am not sure when i will do this though
...one correction though - second point should include numbers ending with 5-9 and ending with 0
Completely forgot about this. Of course the same for Russian (and I think for Czech).
so i will do:
  • any number ending with 0 - not used apart from polish. Should be the same as for 5-9 endings
  • any other number - use the existing plural value. May be the same as for 5-9 endings[/b]
Steven, thank you very much!
Last Edit: July 26, 2013, 07:15:47 PM by boroda74
Xyzzy
Pako has created Polish buttons and they will be attached to the next release of Polish language file.
Thanks Pako!
This is done for the next v2.2 update:
  • 11, 12, 13, 14 items or any other number ending with 0,5-9 add 059 eg. Main.msg.Files059
  • any other number ending with 1 add 1 eg. Main.msg.Files1
  • any other number ending with 2, 3, 4 add 24 eg. Main.msg.Files24
if no translation is provided it falls back to the plural eg. Main.msg.Files9
http://musicbee.niblseed.com/V2_2/MusicBee_Exe_Patched.zip
Last Edit: July 28, 2013, 05:12:11 PM by Steven
Hmm, Main.msg.Files1 already is a translation for '1 file' without parameters. How I can add translation for '{0} file'?
i will change it to use this convention:
#Main.msg.Files9:059#
#Main.msg.Files9:1#
#Main.msg.Files9:24#
