Author Topic: Translator Q&A  (Read 530353 times)
Under Settings -> Device Settings -> Auto-Sync Settings -> synchronise files from: the word "video" remains in English.
its in the next update
butty
Too many contrast fields in (modern) Compact player layout.
Plese see: http://piulento.ddo.jp/tmp/MB-20130506.png
[Comment: this should be a bug in 2.1.4873, not a translation related problem.]
Last Edit: May 06, 2013, 04:54:24 AM by butty
no that is intended so you can set the contrast on the rating, file url and properties elements
see the comment in the translator file - you will need to shorten the "track properties" check box
butty
Roadrunner
Sorry, it's me again with another untranslatable text: The title "Compact Player Layout" (as seen in butty's print screen) has no entry in the language file.
its included in the next language update and will be:
#CPL.frm.14E80D0A#   Compact Player Layout
Roadrunner
Perfect, thx!
Steven, it seems that strings #Sys.tab.344CEE48#  'Layout (1)'  and #Sys.tab.BDFB62DA#  'Layout (2)'  are not used in 2.1.4903.
trying with your file it works fine for me - nothing has been changed that should impact those fields
did you mean something else?
Last Edit: June 05, 2013, 07:28:09 PM by Steven
jistme
It's working correctly in Dutch...
Maybe some very small error or maybe a double entry in your xml?
I've check localization file for duplicates - there are no duplicates.
Sorry, I was using localization file from 2.0 package :)
Last Edit: June 05, 2013, 08:29:29 PM by boroda74
@boroda74, i am using your file that is linked to in the russian topic. Is it possible you are using a different copy?
VX
It's strange but Polish letters with diacritic marks are not aligned with other ones.
The same issue exists in the Polish translation of Additional Tagging Tools Plugin.
Have got a similar issues with diacritic marks in MB localisation to your native language  ???
MB version shown at the screenshot: 2.1.9404
(I'm not sure if it is reproducible with MB 2.0 final, but I can check if needed).
