Author Topic: Translator Q&A  (Read 530073 times)
Lakrits
try
#NPL.tab.655DE83F#   Track Details
#NPL.tab.705229AC#   Lyrics
#NPL.tab.A90A4114#   Artwork
They work! Thanks :)
However, lower case letters with parts beneath the baseline (g, j, p, q and y) get cut off. So, the text needs to be raised just a wee bit.
Lakrits
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
   Du hittar svenska språkfiler i den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
  In hoc filum documenta linguae Latinae nancisceris.
andrea.ippo
In one of the last updates, there is this string related to the theater mode, for which I would need some more context:
#TMP.menu.ShowInDM#   Show in Display Monitor
Thanks
if you have multiple monitors, that menu item will have a list of screens you can choose from to select which monitor the plugin displays in
butty
In version 2.1.4770 and later, there are some un-localized strings.
1. "Layout (2)" in Preference:
http://piulento.ddo.jp/tmp/MB-20130224-1.png
2. "show spectrum visualizations" in now playing window's layout:
http://piulento.ddo.jp/tmp/MB-20130224-2.png
3. "main player panel", "mini player", and "taskbar player" in Layout (2).
http://piulento.ddo.jp/tmp/MB-20130224-3.png
Regards.
they are all in the upcoming file - i will make it available today
Xyzzy
Have the file mentioned on 2/24 been published? With my 3/11 build I have pretty lot of untranslated strings, fe in Layout (2) preferences section.
i still havent published an updated translator file. I plan to do so this weekend
Roadrunner
Hi Steven
In the new translation file some text cannot get translated:
Equaliser and DSP panel:
- "Stereo Enhancer" (already translated under #SE.msg.StEn#)
- "MB Stereo Enhancer"
- "Tempo Control" (the id #EQ.msg.TempoCtl# is ignored)
New and classic compact player configuration dialog:
- "show track properties (bitrate, sample rate, channels, duration)" (already translated under #NPL.ctl.8EB6C56F#)
In addition, during translation process I thought, as most of the text has already been translated in other places, if it would be possible to re-use the same ids whenever practicable?
Last Edit: April 04, 2013, 08:31:53 PM by Roadrunner
Tempo and "show track properties..." should be fixed for the next 2.1 update
MB stereo enhancer i will leave as is
I appreciate what you say about the duplication - the reason for duplicates is because loading the translations for fields in an input form is automated based on the name of the field. If i hard-coded things then it would bloat the program code
jistme
I also mentioned this one in the Dutch topic.
Since it is under the column header 'description', and not under the column header 'name', I think it would be better if it was translatable.
VX
A tip for those who have a problem with downloading the new translation.txt file with Firefox 20 (and perhaps other browsers) - you need to allow cookies on the hosting site. When cookies are blocked the file can't stop loading.
Roadrunner
Both work fine now, thx.
Well, not a big deal, but that leeds to two inconsistencies:
1st) "Tempo Control" is translated including the description, both situated directly over the tempo control
2nd) If you double click to configure the "Stereo Enhancer" it opens a new pop-up whose title "Stereo Enhancer" is replaced by the translation under #SE.msg.StEn#...
Thx for the explanation, of course an acceptable argument.
Roadrunner
A German user found a word, which is, as far as I can see, not translatable at the moment:
Under Settings -> Device Settings -> Auto-Sync Settings -> synchronise files from: the word "video" remains in English.
VX
It's in Latin actually  ;)
