Author Topic: Translator Q&A  (Read 529297 times)
OrB
Hi, it looks like this one dont work any more
! right click/ Send To/ Folder (Move) or Folder (Copy)
!Main.menu.MFtoF#   Move Files to Folder
dont think i had it right from the start! its fixed now
OrB
This one got a problem:
! right click on the Library Explorer
!Main.menu.ShSimArtist#   Show Similar Artists
OrB
the window title "Remove Tags" is not localized
a suggestion is : !Main.menu.ReTa#   Remove Tags
butty
Hi!
How to display "welcome dialog" without uninstalling MB?
I 'd like to check the texts on it.
[edit] One more question:
What is the difference between the words "remove" and "delete"?
In Japanese, they mean the same thing.
Thanks.
butty
Last Edit: September 03, 2011, 09:56:31 PM by butty
Just keep pressed 'shift' key when MB starts to make MB to display 'welcome dialog'.
'remove' and 'delete' may or may not mean the same even in English depending on context :)
Usually Steven uses 'remove' word to designate 'removing from some list/removing link to file' and 'delete' for 'delete from computer'. For Russian localization I'm using translations like 'delete from list' and 'delete' respectively.
butty
Thanks a lot!
I will try the welcome dialog, and re-check the "remove/delete" texts.
butty
there isnt a good way - if you PM me a link to the language file then i can take a screenshot
butty
(This is not a Q&A)
Hello,
I have made a small PHP tool to help checking translation.
Features are:
1. Check for loss of translation
  Count and compare the number of lines: original(English) and translated.
2. Compare lines
  Extract the lines: original(English) and translated for easy review.
Sample output:
*** Error: Line with key 'Main.field.3' is not in the translated one
aaaaaaaa bcccdddd eeeeeeeeeeee ffgghhhhhhiiiiiiijkllll:mmnnnnnnn oooooooo ppqrrrrrrsssssstttttttttuuu vwwxyyz
aaaaaaaa bcccdddd eeeeeeeeeeee ffgghhhhhhiiiiiiijkllll:mmnnnnnnn oooooooo ppqrrrrrrsssssstttttttttuuu vwwxyyz aaaaaaaa bcccdddd eeeeeeeeeeee
   Filename
*** Error: This line has no translation
   Kind
   Typus (translated ver. of "Kind")
Usage:
  1. Edit the line #9 to specify your lang file.
  2. execute "php check.php" on the cmd.exe.
The tool can be downloaded from
http://www29.atpages.jp/~butty/MB-translate/check-mb-lng/check.ph_
(Please replace the suffix with ".php")
May this tool help you.
butty
