Author Topic: Translator Q&A  (Read 529684 times)
Roadrunner
'search' doesn't get translated in the hotkeys panel
Well, it does and it's a very old entry: #NPA.msg.search:# search:
Thanks. I believe it was rendered obsolete at a time a while ago, so I probably removed it to keep my sheet clean.
But it seems to be reactivated, but also repurposed a little bit.
It used to mean 'search in', but now it is intended to mean something like 'search for'.
I noticed that you still have the old intended purpose for it in your translation:  "Suche in:"
For the new purpose I am guessing it should now be just "Suche".
Last Edit: February 16, 2021, 05:57:06 PM by hiccup
Roadrunner
You're right, it seems to be a lookalike re-use without notice... Thx for pointing that out, I will ajust that in the next German translation file.
klint
Hi all.
not sure this has already been reported, but I was not able to find this string in the translation file ("Filter buttons enable...") :
Roadrunner
Hi all.
Works perfectly for me (translation file from 17/8/2020):
#CB.msg.Fbeqfot#
klint
#CB.msg.Fbeqfot#
[/quote]
Thank you! I had missed 2 entries on that date actually. New update uploaded.
Sofocl
The two paragraphs cannot be translated into any language.
! set from the Sorting/Grouping tab in the Preferences screen - click the ... button on a sort set
!Sort.ctl.F0C797E2#   sort by:
!Sort.ctl.38E2DA97#   sort order:
Sorry for my bad English.
Confirmed that they don't work for me also.
These entries must have some history since it looks like somebody appended them with an exclamation mark to comment them out, but changing those back to # won't make them function either.
Sofocl
Thank you for confirmation.
It looks like another flaw, there are no translation lines;
List > Undo Changes
Only one line is present, the other few are missing.
! when clearing a playlist
!Main.menu.ReseLi#   Reset List
List > Undo Changes
I don't know how to replicate it so to get those menu's, but I'll take your word that 'Remove' and 'Add' are missing from the translation file.
Roadrunner
I'm pretty sure, those tags worked sometime (not too long) ago. But now, you're right, they don't. And the  word "remove" is indeed untranslatable ("add" I don't know, how to get).
This is fixed for the next update. The same issue is likely to have affected some other dialogs as well
List > Undo Changes
I need to add some translation entries but I will do so for v3.5
Sofocl
No line for "artist" in "Album Auto-Tagger".
#aTag.col.E8D2641A#	artist
should work. I will put it in the v3.5 new translations
