Author Topic: Playlist / Filter View  (Read 1809 times)
ChriUwe
It would be great to be able to select not only a custom view but also a custom layout for a playlist or filter.
The Incredible Boom Boom
Is this what you're after?
Are you saving each view separately? I haven't quite figured out how things "reset," but the only way to have my layouts and views not take on attributes from others is by not using any of the default ones at all. I also don't quite remember how I got mine to "stick." Try creating a "Default" layout first, then save the layout and view as "Playlist" or whatever. From there, save another layout and view "Playlist Sort." Or whatever. Make your changes in the "Playlist Manual Sort," then save them (to "Playlist Sort") again. Last, save another layout and view as "Playlist Custom Sort"... or whatever. Make your changes, then save them (to "Playlist Custom Sort.")
Maybe that will work.
ChriUwe
I have once tried to perform these steps as described, unfortunately without the desired success  :(
Did you ever figure this out, or do you still need help?
