Author Topic: Keep getting an error while backing up the library and settings  (Read 1724 times)
I realize this doesn't answer your question specifically, but since you are using the Portable version of MB the best and easiest way to do a complete backup of settings, layout, library, playlists (at default location), etc. is just by copying the entire "MusicBee" folder elsewhere, as opposed to doing the Backup Library/Backup Settings procedure.
That should be fixed in the next v3.4 update. It should only happen when the backup is done after files have been re-organised
