Author Topic: Tag Editor doesn't change if you click the selected track in playing tracks  (Read 1177 times)
To see what I mean:
* Open the tag editor
* Select a track in the playing tracks list (see that it loads in the tag editor)
* Select a track in the main panel (also loads in the tag editor)
* Select the same track in playing tracks: does NOT load in tag editor
I initially noticed this because if I removed a track from playing tracks while it was in the tag editor, it would remain in the tag editor even though a new track was (low-light) selected in playing tracks.  If I then clicked on the new track to load it in the tag editor, it wouldn't work until I selected some other track and came back.
I can reproduce this but only when using the Thumbnail view on the playing tracks panel.
Yup, that matches. Thanks!
Sorry, I spoke too soon. This is fixed for going back and forth from the main panel, but not for the second situation I described. I can reproduce it in both thumbnail and track details view.  If I remove a track from Playing Tracks, the next track is selected, but clicking on it does not load it in the tag editor. The previous (removed) track remains in the tag editor.
