Author Topic: Unable to Edit Existing Artwork  (Read 731 times)
pjsteel88
MusicBee v3.3.7491.38139D  (Win10.0), 21 Nov 2020 20:31:
System.Runtime.InteropServices.ExternalException (0x80004005): A generic error occurred in GDI+.
   at System.Drawing.Image.Save(String filename, ImageCodecInfo encoder, EncoderParameters encoderParams)
   at System.Drawing.Image.Save(String filename, ImageFormat format)
   at #=zxtWTmr_fRzcy5Xjdj9Q_8qKPoGRP.#=zfmKl5CFaqjWm(#=zbdn8Y9h66P3cw_yWKhGnAIs= #=z3gtO5A8=, #=z88wOfaCGeaMTPyIqug== #=z07bmKgg=)
   at #=z0uzQ_FXn6hIlGjp7iSYfjrdD5RXYS$NGdw==.#=zb9kaaZWDNuJF(Object #=z9O_irZI=, EventArgs #=zPDFE8Uo=)
   at #=zZMZ4gJLY$uUQMPySc5sEkQ8=.OnClick(EventArgs #=zPDFE8Uo=)
   at #=zZMZ4gJLY$uUQMPySc5sEkQ8=.#=zZjB$p0RBqaIE(Object #=z9O_irZI=, EventArgs #=zPDFE8Uo=)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
You can't edit artwork directly in MB. So please tell us exactly what you were doing and how you were doing it so we can try to reproduce the issue.
EDIT: Perhaps I misunderstood what you wrote. Might you perhaps mean you can -add- artwork?
Last Edit: November 22, 2020, 12:43:23 PM by phred
