Author Topic: Filtersettings  (Read 1397 times)
HaiFi
Hi together,
I am using MusicBee from several PC's. For that reason my complete music bibliothek is saved on a NAS-server in my network.
Everything of the library is saved on the NAS but not the filtersettings.
I found out that the filtersettings are saved  in the "User\.....\Roaming\MusicBee\Filters" folder.
Is there any possibility to change the target folder of the filtersettings?
Are you using the portable version of MusicBee?
HaiFi
No, I am not using the portable version.
Then I suggest switching to the portable version. All the settings will be contained in one folder.
I only did a speed-read, and probably didn't consider your question enough, but perhaps creating a symlink to your nas for this file/folder could be a solution?
HaiFi
Thanks for the infos.
I will check them..
