Author Topic: How to reduce line-height/space gap between song lines in playlist?  (Read 652 times)
clsven
When I look at the lines in my playlists then I like the current font(size) but not the gap between the lines.
From line to line there is a gap/space of approx 5 empty pixel rows.
This space gap is not reduceable by decreasing the font size.
I prefer to see as much songs in playlists as possible without scrolling.
So how can I reduce this space gap to only lets say 2 pixels?
The preferences dialog does not contain an option to adjust the line height.
I doubt that the line height can solve this problem alone. There must be an additional setting in the programs table control setup.
So is there any solution?
You can't set it precisely, but there's a setting in Layout preferences called Row Padding. Changing that to Compressed should improve it for you.
