Author Topic: MiniLyrics Portable for installation on USB key  (Read 4242 times)
baldor
Hi Folks,
I am setting up my complete music library on a USB key to be able to use it everywhere.
So far so good, I was able to install MusicBee, Mp3tag, Xrecode but not MiniLyrics.
I checked and didn't find a portable version of the software.
Ideas?
Thanks
You should look for a MiniLyrics forum or contact the MiniLyrics developer.
MB and its developer have no connection with MiniLyrics.
baldor
Unfortunately, there is no forum for MiniLyrics and Contact page does not work.
Was just trying to see if anyone in the MB community (as this is my main use of MiniLyrics) had the same issue and was able to solve it.
The Incredible Boom Boom
This should work, otherwise you'll need to make your own, if it doesn't. Note that you'll have to open it every time you open MusicBee, instead of it happening automatically.
baldor
