Poll
Do you like to look through album art when browsing your music?
Yes, it's the fastest way to recognize and choose an album
5 (100%)
No, I only look at artist names or titles
0 (0%)
It makes no difference to me
0 (0%)
Total Members Voted: 5
Author Topic: Larger Album Art for Music Tab - SOLVED  (Read 3721 times)
chrismeraz
Hi Steven, your application is AMAZING. Thank you SO MUCH. :-*
Would it be easy to increase the maximum album art display size in the MUSIC tab? Say, 500px per side? That way it would feel more like browsing through vinyl album covers rather than tiny thumbnails.
Last Edit: November 07, 2020, 09:49:45 AM by chrismeraz
johnmillsjr
Is this what you are looking for- or perhaps you mean to increase the max capacity which doesn't seem possible within the confines of the panel.
One idea this does give me is perhaps to add increment percentages along the bottom if the bar i.e
[-90_-80_-70_-60_-50_-40_-50_-30_-20_-10_0 (normal) 110_120_130....
Naturally there's limited size to work with within the menu- so it may have to be in 20% increments.
Due to my disability, I've always a hard time adjust/fine tuning the size slider, Would be great to have the option to click 'picture size' to open a dialog and being able to type a #x# scale or zoom percentage- and possibly have + and - buttons to adjust/fine-tune- either on the drop down menu, in a dialog or both- the bigger the better!
Last Edit: November 07, 2020, 08:08:27 AM by johnmillsjr
Welcome to the forum chrismeraz.
Are you using MusicBee 3.3 or 3.4?
The artwork used to be a bit smaller (I believe 224x224), but for 3.4 the maximum size was increased to 330x330.
chrismeraz
Thanks guys, I didn't know 3.4 was out - yes, that's perfect! 330px per side is just about right! It looks great. Thanks Steven! :-*
Last Edit: November 07, 2020, 09:47:06 AM by chrismeraz
If you're referring to the Album Art view I don't think this would be workable as there is no "normal" size. If you make the window (or panel) wider, the art gets wider. And visa-versa.
Is that happening with your setup?
You must have set something differently then, for me the size of the albumart stays the same.
Only the spacing and the count changes.
Errr ... not, it isn't. I must've been in my alternative universe when I typed that.
Sorry for my confusion.
johnmillsjr
Default would have been a wiser choice of word on my part.
