Author Topic: Bug report of an old version  (Read 1662 times)
NickIst
Not sure, whether it's still worth of reporting, but anyway.
MusicBee v3.3.7367.38620D  (Win10.0), 4 ноя 2020 18:34:
System.ArgumentOutOfRangeException: Индекс за пределами диапазона. Индекс должен быть положительным числом, а его размер не должен превышать размер коллекции.
Имя параметра: index
   в System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   в #=zmbhoq0EWKaet_rhI$w11AZA=.#=zsmDV6ax5g$GeW2v$1Q==(Object #=z4OVDJ6s=, EventArgs #=zHB5no$s=)
   в System.Windows.Forms.Control.OnClick(EventArgs e)
   в #=zKwYiJ0k338oWDqlffcfgUjDbFtkB.OnClick(EventArgs #=zHB5no$s=)
   в System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   в System.Windows.Forms.Control.WndProc(Message& m)
   в System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   в System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Exactly what were you doing when the error happened?
If you patch to the latest version (either 3.3 or 3.4)it's more than likely been fixed. See my sig.
It certainly won't be fixed in the version you're using.
NickIst
Yeah, I know that it won't be fixed for the old version. I searched an image for an album cover.
Is it reproducible?
Does it happen every time you search for artwork? Or only for one specific album?
And exactly how are you searching?
Last Edit: November 04, 2020, 10:58:15 PM by phred
NickIst
