Author Topic: Two same songs on playlists  (Read 662 times)
robinwood
Hi, i'm on musicbee 3.3.7261, I'm really happy to use this software, it's perfect for me (that's why i've donate something because the work is really great :) :) )
and i have a problem, concernin playlists:
On a playlist for instance, sometimes, i've put 2 times the same song on it, so the same song appears twice
           https://zupimages.net/viewer.php?id=20/44/jrno.jpg
how can i hide automatically the second song? (i've tried to hide duplicate songs with the menu, but it doesn't hidding anything...)
           https://zupimages.net/viewer.php?id=20/44/dna5.jpg
Right click on the playlist, go to List > Remove Duplicates.
If you're not getting notification when you add a duplicate, you probably need to tick "warn when duplicate tracks are added to a playlist" in General Preferences.
