the back button takes playback to the start of the current track when > 20 secs, and then the previous played track even when shuffle is enabled, right back to when playback was initiated.
I use that all the time without issue.
Perhaps you have playback follows cursor enabled?
Thanks for the input!
The above is the exact behaviour I would want / expect. Alas, my experience is very different. (checked, and playback follows cursor is NOT enabled)
But - turns out, having the media hotkey mapped to the Playlist History Plugins' Previous functionality is the root of the utter erratic behaviour I've been seeing recently, and not the default Back/Previous vehaviour...
But, I started to use this (after re-enabling the default Media Button: Previous Track hotkey mapping I realized again) as :
- double-clicking a track for playback erases the history queue, therefore disabling the Previous Track functionality altogether (i.e. re-populating the upcoming tracks queue in any way seems to always flush the history / previous track queue)
- this means, navigating to a different playlist / tab will also always flush the history / previous track queue
- so Back / Previous only works IF one sticks to only play tracks within a single tab (library or playlist), AND only if never double clicking a track...
Whereas, I would love to have the Back / Previous function based on a complete history / previous track queue for the current MB session, not just since 'playback was initiated', and Back/Previous being able to traverse the complete playback history, and even jump jump tabs/playlists as necessary (but, this is probably more complicated... [as this would also affect the 'Next' functiolnality, as it would need to go back-forth between the history, until it hits the point of the last played track, after which Next would re-engage to playback the next queued track in the Now Playing queue...])
Fingers crossed this could be something not-too-complicated to add some time...
Churs.
c.
