Hello,
I recently discovered a problem: Whenever I change or set a rating then the tag becomes unreadable by other programs.
Some more infos:
- I activated the setting that the ratings are saved in the file
- The program MP3tag shows the error "Bad ID3v2". ID3v1 still work. My NAS-mediaserver (Minimserver) also can't read the tags
- The tags are saved in the ID3v2.4 format (I need that format so that Minimserver can read multiple tags)
- If I open the file-editor (via shift-enter) and enter the rating there, then it is saved properly and the tag remains intact
- I use MusicBee version 3.3.7491
- I am pretty sure that the rating worked without flaws in previous versions
Can anyone help / advise?
Best regards
Christian
