Author Topic: Invoking registered command from another plugin?  (Read 7961 times)
TRoJAnV
Hey,
This is kinda a two part question.
1) How is the "mbApiInterface.MB_InvokeCommand(Command command, object parameter);" used? Is there an example of this function call someone's used before as an example I could see?
2) Is it possible to call a function that was registered by another plugin?
For example, if in Plugin A I did: "mbApiInterface.MB_RegisterCommand("MyFunction", DoSomething);"
In plugin B: Can I call that registered method? If so how would I go about it?
Thanks!
1 - its just a easy way to invoke musicbee commands - have a look at the Command enumeration
2 - not in the current api
