Author Topic: Hotkey to switch libraries?  (Read 1200 times)
NailJ
Is there one, or can I set one up somehow?
I use two libraries in MB, one for popular music and one for classical and would like a hotkey to make switching between the two easier.
Or, maybe, the best option is to have two different (portable) Musicbees, one for popular and one for classical?
Thanks
There isn't one, nor can the end-user create one.
Have you looked into filters? Create a filter for all your classical music and another for the rest. No need for two libraries and no need for two installations. https://musicbee.fandom.com/wiki/Filters
Yes, that's what I do. One filter Genre contains Classical, one filter Genre does not contain Classical and pinned tabs for each filter. Works beautifully.
NailJ
Thanks guys!
Never used filters but will give it a try
 :D
That's what I have decided on a while back, and I have never regretted it.
But you'll probably only find benefits in that if you have a large classical collection, and if you like to have differentiating layouts, custom- and virtual tags, and/or skins between your classical and your non-classical library.
