Author Topic: Difference in number of albums  (Read 2648 times)
Stgo
Hello, the number of albums in the library does not match the number of albums of all the "Music" artists.
I love the program.
Cheers, :)
Hi, welcome to the forum!
Can you give us a screenshot to clarify where you're looking for the numbers? Thanks.
That's exactly it, thank you.
If I'm reading right it's 2280 vs 2281. That's odd, indeed. I know the library report is filtered by the view you're in, but then so is the thumbnail browser. The only thing I can think of would be to try rescanning all files and/or run the compress library command (both found under Tools > Advanced).
Last Edit: October 07, 2020, 06:31:37 AM by psychoadept
If the difference is one album, then probably what is happening is tracks with no album is being consolidated and counted as 1 album.
I will check that out later
edit:
yes that is what is happening and fixed for the next v3.4 update
Last Edit: October 07, 2020, 08:12:03 AM by Steven
Stgo
Thank you for the time you dedicate to me.
In my case I don't think it's a track without an album, it must be a track archived in another album.
I will continue to investigate. :)
Steven will probably post his update shortly. Be sure you install it and give it a try before you decide for sure that it didn't solve the problem.
Last Edit: October 07, 2020, 09:35:11 PM by psychoadept
Stgo
 8) Perfect, the counters have been equalized. Thank you, :)
