Author Topic: Excessive CPU Usage  (Read 2406 times)
EnduringGuerila
Historically (at least 8 years) I haven't had an issue with Musicbee and CPU usage. I have a 9900k and Musicbee, even without music playing, is using tons of resources. Often peaking at 90% which is 100%ing my CPU since I always have other stuff running.
I cannot play games at all with musicbee running anymore. I first noticed this issue 3 weeks ago, I updated Musicbee to "3.3.7491 P" in hopes that would help.
Just as I'm writing this, Musicbee dropped to only 20% usage without music playing. It's also using 1.3GB of ram, which I don't care about too much, but not ideal. I just resumed the music, and after like 30 seconds the usage dropped to 11% while playing FLAC. I don't know what Musicbee is doing in the background and I'm pretty sure it'll start doing it again.
Music Stats at Last.FM
My MusicBee Skin
My Portable MusicBee Setup (panel layout saved in \MusicBee\AppData\Saved Settings\Layouts)
EnduringGuerila
Before posting, I did search for similar issues but I didn't see anything that quite matched my issue. I'm pretty sure I don't have the DNLA plugin and I don't stream music. I have all FLAC and searched the plugin folder for "DNLA" which found nothing.
My MusicBee Skin
If you do have any plugins, they should show up in your preferences. But I don't suppose anything changed recently with your AV software?
EnduringGuerila
Yep, Musicbee just spiked to 85% again while playing an album. Stayed like that for 30 seconds, dropped to 10% for 3 seconds, then jumped back to 80%.
My MusicBee Skin
Assuming you actually looked for "DNLA" you won't find anything because it is "DLNA." And the dll you should be looking for is mb_Upnp.dll. You should really check the plugins preferences from within MB to see if it's there. Then click on Disable, then on Uninstall, and then go to the plugins folder using a file explorer and make sure mb_Upnp.dll is gone.
EnduringGuerila
omg, it was DNLA, I overlooked it in the preferences/Plugins section. Disabling it dropped musicbee to 0.1% while playing FLAC. RAM is still at 1GB but I don't care since I have 32GB available and rarely even get close to maxing that.
My MusicBee Skin
EnduringGuerila
Thank you !
You're welcome. Glad you got it sorted out.
When you said extremely high CPU usage and that you were "pretty sure" you didn't have this plugin enabled, I said to myself, it's the only plugin for MB that has this behavior. So I figured you must have it installed.
Last Edit: October 03, 2020, 10:36:49 PM by phred
