Author Topic: Remove playlist tracks from main collection  (Read 747 times)
TwoTonYeti
Hi all,
I mistakenly imported all of my playlists into my main collection. Is there a way to compare a playlist to my main collection and auto-remove the playlist tracks from the main collection?
I realize that I could simply "delete from library" all of the tracks in my collection and then rescan the specific songs I want in my main library back into MusicBee, but I would like to preserve my Play Count info if possible.
Any pointers on advanced tag search/replacing or tag copying would be appreciated.
- Yeti
Hi, welcome to the forum!
You can do a search for "Playlist has a value", and it should show you any tracks that are in static playlists. It doesn't sound like you'd be dealing with auto playlists here, anyway.
Why can't you just open the playlist in MB, select all the files in it, and hit the delete key?  Make sure you do "Delete from Library Only" and not library and computer if you don't want to delete them from your computer, too.
TwoTonYeti
Hi Frankz,
AFAIK I thought that removing tracks from Library will reset playcount values and ratings values - if this is not the case, that would be fantastic. I just didn't want to risk losing my "progress" as I go through my library.
If you're concerned about losing data on the playlist tracks, you shouldn't remove them from the library. Try moving them to the inbox, instead.
Maybe I'm confused about the difference between "remove the playlist tracks from the main collection" and "remove the playlist tracks from the library."
If you just want to segregate them for review, then the Inbox suggestion is your best bet.
TwoTonYeti
Sweet - this did just what I wanted. Thanks!
