Author Topic: Volume Adjustment option greyed out  (Read 1494 times)
Xiam
I would like to use volume adjustment on individual albums to make sure they're all at the same volume however, when I click Edit on an album and go into settings to enable volume adjustment it's greyed out, what am I doing wrong?
Hi, welcome to the forum!
What format are these files? Is it disabled if you select only one file?
Xiam
both .flac and .mp3 files are greyed out, individual files are greyed out too.
There is no code in MusicBee to disable the volume adjustment control and trying now its working fine. Infact in your screenshot the control button is blue so active.
Xiam
I do not believe that it is working fine, whenever I tick the box and save and re-open it is unticked. And I have not noticed any difference in the volume even with it set to 200%.
Xiam
Ok, I did some more testing, you're right, it does work, when I put it at -100รน I can't hear anything. I guess I was wrong and +100% just doesn't increase it that much.
