Author Topic: Use tag contents as search string in auto playlists.  (Read 663 times)
mrbenn
I want to have an auto-playlist to identify compilations that do not have the "Various Artists" tag as Album Artist.
As a starting point I set the filter as: <Artist> is not <AlbumArtist> (but of course I type <Artist> and it looks that that as a string not a variable value).
Can you use the filter on auto playlists this way?
thx
You may have better luck with "does not contain" rather than "is not"
EDIT: Nah forget it.  I don't think you can have it do tag comparison.  I'll think on it, but you'll probably have better luck exporting Artist Album and Album Artist for your library to a csv and then doing this in a spreadsheet.
Last Edit: September 12, 2020, 07:45:56 PM by frankz
You can probably do something with a virtual tag, like $IF(<Artist>=<Album Artist>,"yes","no")
This is why it's a good idea to mark your compilations with the itunes compilation flag
