Author Topic: How to hide the Back and Forward buttons?  (Read 1296 times)
mmakes
The Back and Forward buttons seem to be used only for Music Explorer. And since I rarely use Music Explorer, they pretty much stayed eternally disabled. Is there a way to hide them?
Thanks for the help in advance!
You could edit the skin so that the 'disabled' arrow has the same colour as the background, making them invisible:
How to change colours of a skin that you like
I'm guessing OP wants to reclaim those pixels.
Perhaps, but as explained that is not possible, and he did say 'hide', and making them black will do that for that skin.
Sofocl
+1 to the ability to remove buttons.
Topic in wishlist: Full Customization Header Bar
Sorry for my bad English.
