Author Topic: volume problems  (Read 1064 times)
wilivarob
Hello, I am testing the program and for now the only problem I am presenting is that when I play a video on YouTube or when I play, I leave the musicbee in the background to listen to my music and it is automatically lowered giving priority to either the video or the game, how can I solve this.
Hi, welcome to the forum!
That isn't something MusicBee does on its own. You may have other software that is adjusting the relative volume of programs on your system. There is even some built-in Windows control for this, although it's supposed to only happen when you're using VOIP.
Last Edit: August 31, 2020, 08:39:25 PM by psychoadept
wilivarob
and how do i check that?
It is already becoming annoying, since I have to turn up the volume on the player and it sounds quite harsh and when playing the volume is leveled in such a way that I can hear the game and the music that I am playing, but when I leave the game it triggers the one with the music player.
If you look down the page I linked, there are instructions for how to fix it if Windows is the problem. If that's not it, you might also check on your specific audio device and see if it has software included on your system. Since it's happening with multiple programs, it's likely not one of the specific programs you're using.
