Author Topic: Remove picture  (Read 3640 times)
gorney
does not work, for me anyway. Anyone maybe know why?
Nothing happens at all?
What picture are you trying to remove?
From where?
And how?
gorney
The picture in Track Information (did not know there were any other pictures).
Right click image>Remove does not do anything.
There are pictures in Albums view, Album & Tracks view, Now Playing view, and on and on.
Does this happen with all artwork, or just one album/track?
Is the picture embedded in the music file or saved as an image file within the folder where the album/track is?
Is the file read only?
gorney
UPDATE: For the first time, I got a confirmation asking if I want to "remove the clicked picture" (embedded).
Before today I was unable to remove any (embedded) artwork.
Your artwork is embedded, correct?
Are the files read-only?
Is the issue resolved?
gorney
Some artwork is embedded and some is in album folders.
I don't believe they are read-only.
The issue is unresolved. I just tried to remove an embedded file and nothing happened, so I believe this is only occuring with embedded files.
I suggest you check the files where you can't remove the artwork and determine if they are or are not read-only.
If they are read-only, you've got to clear that in order to remove the artwork.
gorney
Thanks but I don't know where the files are. They somehow became embedded with the audio file.
If you would just do a file name search with Window's own search function in File Explorer/Windows Explorer, you would know where your audio files are.  Then you could right-click them, check "Properties", and see if the "Read-Only" attributes box is checked.
Another possibility is that you have MB configured in Tags (2) preferences to download artwork but not save it, in which case there's nothing to remove (although you shouldn't see the remove command in that case). If you open the tag editor, does the artwork you're trying to remove show up under Artwork?
gorney
I know where my audio files are but neither they nor the image in at least that folder are read-only.
gorney
Tags (1) is set to embed picture in music file.
Are either Tags (1) and (2) the tag editor?
I'm talking about Tags (2) in Preferences, under Auto-Tagging: Artwork.
