Author Topic: Inconsistent Play after Stop  (Read 700 times)
bee54
I have some files for an audiobook in the Audiobooks tab. If a file is playing and I press Ctrl+S for Playback: Stop, the file stops playing. The bug lies in what happens when I click the Play button to resume. The expected behavior is that it will continue playing at the time it was stopped. But, in certain cases, clicking Play will cause MuiscBee to “resume” at the very beginning of the file. I’ve noticed that this happens in a predictable way.
If I press Ctrl+S toward the beginning of a file, playback continues where it stopped.
If I press Ctrl+S toward the middle of a file, playback continues where it stopped.
However, if I press Ctrl+S toward the end of a file, playback continues at the start of the file.
For duplication / testing purposes, I have found that pressing Ctrl+S within the last ~10 seconds of a file, then pressing Play, causes this issue to manifest fairly consistently.
Verssion 3.3.7491
yes that sounds right. MB considers the file complete if stopped towards the end of the file
