Author Topic: Strange bug! Makes it practically impossible to use the turntable!  (Read 1443 times)
user2010
The player stopped working correctly!
If I want to listen to a song, I drag and drop it onto the MusicBee player with my mouse! Immediately after dragging, it is copied to the player, up to 100 copies! AS?
If I drag and drop a few songs, maybe up to 1000!
The screenshot shows what it looks like for one song!
https://imgur.com/LQPmJOx
Last Edit: August 03, 2020, 12:42:43 PM by user2010
Hi, welcome to the forum!
If you open the tag editor for one of these files, do you see something about a cue sheet on the main tags page, under the artwork and ratings? If you're not sure, just post another screenshot
user2010
If I get you right?
I post screenshots.
If I was mistaken, please explain again!
Google translator. :(
1.
https://imgur.com/hsfOSTK
2.
Last Edit: August 04, 2020, 01:51:12 PM by user2010
The first screenshot looks like the one you posted before. The second one, I'm not sure what's going on. Is that the vertical tag editor at right? What do you get if you select a track and hit shift + enter?
Last Edit: August 04, 2020, 05:53:36 PM by psychoadept
user2010
Yes. The first skin shot is a replay!
I press Shift + Enter a window opens!
I attach the screen!
https://imgur.com/Os1jkN3
Hmm. That's one of the files that is duplicated?
user2010
Reproduces. Each added file will be multiplied in exactly the same way, I will add two strings, not about 200, add 3 about 300, and so on :(
The previous version worked without problems!
Could you let us know what version you're currently using? (Help > About)
Also do you know which version your were using previously?
If you edit one of the files are all selected?
The only thing that splits files is a cuesheet
user2010
Yes, if I select one-all are selected! (Specifically copies of this file!)
MusicBee
Version 3.3.7491 Store
user2010
In the list playing, I select a file, click the right button! I select the delete menu item, all files are selected,but there is no deletion!
I don't think there exists a delete option for the now playing list, only remove.
What language have you selected to use MusicBee?
user2010
I didn't delete everything! Simply, by pressing the right button, I select the option - delete!
But instead of deleting, it selects all the copies in the list!
The language of the program is Russian. Music files in English and Russian!
