Author Topic: Can't edit cuesheet  (Read 2489 times)
djmst
i can't edit a cuesheet. When i try this, i get an error:
MusicBee v3.3.7491.38089Store (Win10.0), 1 Aug 2020 18:03:
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei #=zLqUKIPGNn36gRoytyJxIPlcl7dWL.#=zKNI68Hm9$EEX(Object #=zLa1Ink4=, EventArgs #=z614nzDw=)
   bei System.Windows.Forms.Control.OnClick(EventArgs e)
   bei #=zkxPwEgpbqlyH5MwA11oLVr4=.OnClick(EventArgs #=z614nzDw=)
   bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   bei System.Windows.Forms.Control.WndProc(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
thanks a lot for help, Mike
does that error happen before the edit cuesheet dialog has opened, or after you attempt to save the cuesheet?
djmst
Hi Steven,
that happens when i click on the SAVE-Button (actualize) in the cuesheet window.
Last Edit: August 03, 2020, 02:36:10 PM by djmst
djmst
Hello Steven, do you already have a solution for me?
Thank you, Mike
this should fix the issue:
djmst
Hello Steven,
Thank you for your answer. I'm using the store version, how can I replace the files there?
You can't. Either uninstall the Store version and use (ideally) the Portable version, or the Installer version. If you want to keep using the Store version you'll just have to wait until Steven creates one, which probably won't be for a while.
Both non-Store versions are not only very easy to update, but update quite frequently.
If you go the Portable route, make sure -not- to install it in a Windows protected directory (i.e. c:\users) but rather something like c:\MusicBee.
djmst
Hello phred, thank you for your support. I've changed now to portable, store-version has been uninstalled.
Same error here:
MusicBee v3.3.7491.38139P  (Win10.0), 8 Aug 2020 19:41:
   bei #=zJcsg4vkKvBoeIC79T8G9_cevmWSH.#=zb9kaaZWDNuJF(Object #=z9O_irZI=, EventArgs #=zPDFE8Uo=)
   bei #=zZMZ4gJLY$uUQMPySc5sEkQ8=.OnClick(EventArgs #=zPDFE8Uo=)
   bei #=zZMZ4gJLY$uUQMPySc5sEkQ8=.#=zZjB$p0RBqaIE(Object #=z9O_irZI=, EventArgs #=zPDFE8Uo=)
   bei System.Windows.Forms.Button.OnClick(EventArgs e)
   bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
   bei System.Windows.Forms.Button.WndProc(Message& m)
I also did a fresh install, same here. It happens, when i change a cuesheet and try to save.
What should i do now?
Last Edit: August 08, 2020, 06:47:42 PM by djmst
The Incredible Boom Boom
Did you replace the portable installation .exe with the patch Steven linked to above?
djmst
Hello, I'm very sorry, but I missed the link... my mistake. everything is working again now.
Thank you all for your help.
Greetings, Mike
stay healthy
