Author Topic: Opacity settings for Mini Player view  (Read 1265 times)
sn0uts
Currently only applicable to Compact view.
Use case is that I often play a lot of longer files (radios, mixes, podcasts) where I tend to interact with the progress bar more often than global keyboard controls or controls minimised to taskbar would allow. At the same time however I'd like the player to be as discreet as possible while always visible.
