Author Topic: new to musicbee just trying  (Read 726 times)
mikemcsw
I want a player that will play native dsd files...can this play a dsf file where it will display dsd on my dac (topping d50s)...i don't want it converted to pcm....it uses wasapi i think.
also, does it have capability to play from dlna host?
mikemcsw
so i downloaded the plug in for dlna and it worked perfectly and sounds great.
Question, do you know if it sends the file natively via dlna or does it convert it first?
e.g. when i play a dsf file it play great to my marantz avr via dlna...just curious if it converts it to pcm or sends it natively to the marantz...my marantz plays both dsd and pcm via dlna, but not sure which format it is receiving.
