Author Topic: Where to put localization file  (Read 1277 times)
DrRoboculous
Where does the new .txt file go? I put it in Localisation folder.
Last Edit: July 23, 2020, 05:11:55 AM by psychoadept
What text file are you referring to? Jukebox View is a view, not a text file. Depending on what view you're currently using, click the upper left corner of the main panel (Albums, Albums & Tracks, Artist, etc) and the drop-down will have an option for Jukebox.
Again I don't know what text file you put in the Localisation folder, but get it out of there.
DrRoboculous
This has nothing to do with the Jukebox view. Just the Latest Version post for 3.4 links here and i can't post a reply on that post.
 This is what it says
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
https://getmusicbee.com/patches/new3.4.txt
That's the .txt file i'm talking about.
Then why did you put it in the Jukebox View thread?
I suggest you put your question in the Localization thread which is found under the Customization section. But if you're not doing a language translation of MB you don't need the file.
DrRoboculous
That's why. And i don't know if it is a localization issue. I have no idea what it's for. But nevermind; it must not be that important.
I have no idea what you're doing. And apparently neither do you. If you don't know what a localization file is why are you attempting to use it? I suggest you spend some time looking at the Wiki.
