Author Topic: MusicBee crashes and refuses to launch due to missing font Segoe UI Regular  (Read 4527 times)
MeH
The latest version of MusicBee Portable (v3.3.7491) fails to start just because I have disabled Segoe UI Regular on my Windows 7 system  :-X
All other programs work fine and with no problem. The only other one that crashed on startup due to missing Segoe UI Regular font was Subtitle Edit. That bug was fixed after I reported it to Subtitle Edit's developer (Nikse.dk/subtitleedit).
The complete error log is:
19/07/2020 5:10:41 PM - 6.1.7601.65536 - 3.3.7491.38139P - System.ArgumentException: Font 'Segoe UI' does not support style
'Regular'.
   at System.Drawing.Font.CreateNativeFont()
   at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean
gdiVerticalFont)
   at System.Drawing.Font..ctor(FontFamily family, Single emSize)
   at #=zkaGS$fzD9GXdZbnVkP$kbuVajmzq.#=zEfRnGuVgJQ2D.#=zznFdti8=(#=z$y65kyfFq1pitxGwSGqOVr7Dc5Um #=zcqcE6$BiXb40)
   at #=zkaGS$fzD9GXdZbnVkP$kbuVajmzq.#=zznFdti8=(#=z$y65kyfFq1pitxGwSGqOVr7Dc5Um #=zcqcE6$BiXb40, #=zmlxsCNrI1FTBHKJbmIia6ZClBUlw
#=zpxrEDYM=)
   at #=z30QA_WQ7rq9Ldwwjg1TwqZI=.#=zi8KX$_9$8N2F(#=z88wOfaCGeaMTPyIqug== #=zgvKElllmN9T7, String #=zhCJjUTM=)
   at #=z30QA_WQ7rq9Ldwwjg1TwqZI=.#=zmD3V5t0kMO9g()
Hope it's fixed easily and soon  8)
I'll probably regret asking, but why would you remove one of the default fonts used by the operating system?
I would suggest reinstalling the system font. Launch MB and -then- you can change the MB fonts. Once all the fonts are changed delete Segoe and see if MB restarts.
MeH
Well, it looks better to me  8)  Segoe UI Regular texts stand too upright while with it disabled, text lean forward a bit, as it can be seen in the screenshot, and that looks better  ;)
MeH
Well, don't you think it's a simple bug that should be removed?!  :-\  :-X  8)
I would suggest reinstalling the system font. ...
I think you are creating problems yourself by using an obsolete operating system, and instead of just selecting some other font that you like better, deleting what is pretty much the default font for Windows and most of it's applications.
And I find it a bit rude that you immediately label and post this as being a bug on MusicBee's account.
I don't think anyone but yourself would consider this a bug. And -you- are the one that caused it by removing a system font.
I'm moving this to the Questions section as it's clearly not a bug within MB.
If you don't want to try the suggestions offered, I don't think anyone is going to be able to help you.
I'm surprised more programs don't have problems when you remove a font that's expected by the operating system.
I'm also surprised Windows doesn't just automatically reinstall it.
Have you tried making a copy of the italic version you like and renaming it to be same as the regular version?
It might be that easy, but I'm not going to test it.
MeH
Win 7 isn't obsolete! Obsolete is Win XP  :-\
As I mentioned before I've disabled Segoe UI Regular and haven't deleted or removed it. And this IS an MB's bug. Even if I use Win 10 and disable Segoe UI Regular, this problem still exists. I'm using about 100 programs on my system, from office software to CAD software, web browsers, audio/video/image editors, media players, ebook readers, IDEs, text editors, etc. and none of them have any problem. This is a bug that can be simply fixed  8)
And if you find it rude, that's your problem  :-\
Last Edit: July 28, 2020, 03:01:48 PM by MeH
MeH
Well, no problem. This IS a bug but as I said no problem  8)   I just wanted to give MusicBee a try, and it sadly failed  :-\  I have many other alternatives  ;)
Last Edit: July 28, 2020, 02:44:44 PM by MeH
Windows 7 is 10 years old and Microsoft stopped supporting it six months ago. In computing terms, that's obsolete, especially for an operating system.
But not the cause of your problem anyway.
How have you disabled it without uninstalling it?
You could delete a heap of random DLLs from the MusicBee installation folder and it won't run then either.
Would that be a bug?
If MusicBee won't run because it uses Segoe by default, you could try editing MusicBee3Settings.ini in a text editor and changing this section by hand to use a font that you don't have a vendetta against. I have no idea if it will help.
<GUI_Font>
 <FontFamily>Arial</FontFamily>
 <Size>9</Size>
 <Style>Regular</Style>
</GUI_Font>
It's also possible that it's some Windows component used by MusicBee that expects Segoe to be present.
It may not be possible to fix it.
MeH
I know that very well  :-X  Win 7 is a bit outdated but not obsolete!  8)
As I said, Segoe UI is present in my Fonts folder and I haven't removed it. I've just disabled it via registry.
hangglidingthejoker
Agree. I have an old laptop I use from time to time. With SSD and 8 GB RAM. It is perfectly usable with Windows 7, and just dies with Windows 10. I can even do video editing there, with this software though [link removed by moderator]
Last Edit: June 13, 2022, 02:24:54 PM by phred
