That's right. If you're going to have giant, heavily compressed files on a slow drive on a slow bus, then you shouldn't continuously monitor OR scan on startup IMO.
Your best course of action would be to put files that you want to add to your library in a separate folder and then manually scan that when you want to add the files and then auto-organize the files to their ultimate location. That way you're not scanning 100,000 files from a slow drive on a slow interface just to find 10-12 new files every time you want to add an album to your library.
I disagree with this, because that's not how
Continuously monitor works.
It
isn't constantly checking files to know when something has changed.
Instead, MusicBee asks Windows to tell it when a file or folder is updated.
It isn't so much watching every file, as it is listening for only those few that change.
Obviously, there will be some difference in responsiveness if you use another program to retag hundreds of files at a time, because at some point MusicBee still has to read them to get the new information. But for normal use, when you're occasionally updating an album or two at a time, continuous monitoring works just as well on an external USB drive as it will on an M.2 drive.
There can sometimes be issues with continuous monitoring on non-local drives (e.g. mapped network or NAS drives), but that's due to limitations in the Windows file-monitoring API, not MusicBee. And they usually mean monitoring doesn't work at all, not that it works inefficiently.
For
Scan on startup though (or the equivalent
On startup check for updated or missing files), MusicBee
does have to check each file to find what has changed. But it's very fast and happens in the background, so I still wouldn't dismiss it as an option for automatically keeping a library up to date.
I use this on my work PC, where I access my 100,000+ track music library from an external Seagate drive. On startup, MusicBee will scan the library and report back on changes within 5 minutes or so.
