Author Topic: Identify Tracks NOT On Any Playlist  (Read 1028 times)
xavier
Does anyone know how to identify tracks that are not on any playlist?
I have 2 Genre Categories (Classical and Popular) and 2 main Playlist Folders (Classical and Popular) each populated with subfolders and smart playlists.
The number of tracks for the Popular folder differs from the number of tracks under the Popular filter.
How can I identify which "Popular" filtered tracks are not under the "Popular" main playlist folder?
Thanxs
If I understand correctly, you could copy the tracks of the Popular auto-playlist into a static playlist, then where you're showing the filtered "Popular" tracks, display the "Playlist" column and see which ones are blank there.
You can't display whether something is in an auto-playlist, which is why you have to copy that playlist to static to do this.
xavier
Frankz,
You're my Hero
It worked perfectly and fast (which I wouldn't think it would with almost 17K tracks)
A million thanks
