When you try to edit tags inline (it often happens with comment tag to me) for an unknown reason although the window is activated whenever i start typing it loses it's focus after 1-2 keystrokes, it exits the inline edit mode and whatever i typed disappears.
Usually this happens if you try to type immaterially when the inline tag edit is activated.
update
It's actually losing focus even if you don't type anything.
Update 2
After some testing i think that the problem is happening when "Automatically refresh matching tracks" is enabled on the playlist that the track belongs.
Update 3
Now that the "Automatically refresh matching tracks" is deselected whenever i try to rate a song the list is flickering and sometimes it jumps to the first song (Top).
