Author Topic: "Thread failed to start" error  (Read 976 times)
Irzagald Arde
Hi. I joined now to ask a question about an error. Yesterday when switching between songs MusicBee stopped playback and an error appeared with a yellow "!" and said: "Thread could not start." I closed MusicBee and started it again and it's fine from then... What was that error about? Thanks in advance.
The error is too vague to offer any suggestions
Irzagald Arde
It was reported within MusicBee interface... Does MusicBee have a folder where it stores error logs?
Help > Support > View Error Log
Look at the timestamps and see if there's an entry from the time you experienced the error. If so, copy and paste it here.
Irzagald Arde
I think this is it.
23.6.2020. 16:50:18 - 10.0.14393.0 - 3.3.7310.31925D - System.NullReferenceException: Object reference not set to an instance of an object.
   at #=zWnZV219GO9SeTCB6Kb6JXeQ=.#=zPzbiC0kXAMiL(String #=zJe1pJ38=, List`1 #=zIDRFrU4=)
   at #=z1H0fDEfDv7fc6_k_aB1Doqc=.#=zNr3igZ8=.#=zdX0kzsw=()
try updating to the latest version from the first forum topic
Irzagald Arde
I updated but I don't know did I do it right. I downloaded the latest full version installer and just installed it over the former version. Is that ok or should I uninstall before installing a new version?
Installing a 3.3.x over a previous 3.3 is fine. If you're asked if files should be overwritten, say yes.
