Hey!
I've been an iTunes and mac user for 20 years (although I've always been a android guy), but now I'm migrating over to a windows machine, and found MusicBee to bring my music library over.
Pleasantly, I've found MusicBee to be light-years ahead of the windows version of iTunes, but I have a few small questions as I settle in and grok the new platform:
Right from the word go, MusicBee found my iTunes library on the PC, and loaded it in near perfectly. But, when I look at the file system, I notice that MusicBee has created its own directory in the music folder, and copied none of the songs over to it, leaving them where they are.
-Am I right in assuming this means MusicBee is agnostic about song file location, as long as that file doesn't move location after it's been entered into its database? (as opposed to iTunes, which wants every song it interacts with to be inside its own directory, and will make copies of every song opened with it)
-When I deleted a song from the music tab, I was prompted and chose to delete from both the library and the computer. However, when I popped over to iTunes, it wasn't missing, and was still sitting in its proper directory. Am I missing something?
-As an experiment, I used MusicBee to open a song that was not a part of the iTunes library I initially imported. It played fine, and I could manipulate the file as normal, so I put it into a couple of my playlists. However, when I searched for it in the all music tab, it was nowhere to be found despite being perfectly find-able in its playlist. Is the music tab an incomplete list? Does it only pull from specific directories?
Thanks for any insight you guys can provide as I learn!
-Nick
